Print, copy and scan with the entry-level multifunction printer for home and office. It's super-simple to set up and use, and allows smartphone printing for extra versatility.
The PIXMA TS3450 is a compact and easy-to-use printer, scanner and copier. It’s simple to set up, with wireless connection at the touch of a button. Control it remotely with the latest technology: you can copy, scan or print from smartphone and tablet using the Canon PRINT app, or print app-free with AirPrint (iOS) and Mopria (Android). Access Point Mode allows you to connect your device directly to the printer without the need for an internet connection or router. Keep your documents crisp and images bright with FINE cartridges, and get creative with the Easy-PhotoPrint Editor app and Canon Creative Park. This all-in-one inkjet printer is an ideal first printer, with essential features at an affordable price.
Product Description | Canon PIXMA TS3450 - multifunction printer - colour | Device Type | Multifunction printer | Printing Technology | Ink-jet (colour) | Inkjet Technology | Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink | Max Printing Speed | Up to 7.7 ipm (mono) / up to 4 ipm (colour) | Max Printing Resolution | 4800 x 1200 dpi (colour) | Scanning | 600 x 1200 dpi | Display | 1.5" | Original Size | 216 x 297 mm (max) | Original Type | Sheets | Media Size | 89 x 127 mm (min) - 215.9 x 676 mm (max) | Media Type | Plain paper, glossy photo paper, magnetic photo paper, restickable photo paper | Standard Media Capacity | 60 sheets | Connection Availability | Yes | Interface | USB 2.0, Wi-Fi(n) | AirPrint Enabled | Yes | Office Machine Features | PIXMA Cloud Link, access point mode | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 43.5 cm x 32.7 cm x 14.5 cm | Weight | 4 kg | Enclosure Colour | Black | Manufacturer Warranty | 2 Years |
General | |
Printing Technology | Ink-jet - colour |
Display Diagonal Size | 1.5" |
Display Colour Support | Monochrome |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 20 |
Copying Features | Fit to page, Borderless copy |
Printing | |
Inkjet Technology | Canon FINE (Full-lithography inkjet Nozzle Engineering) |
Ink Cartridge Configuration | 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, black |
Colour | 4-ink |
Scanning | |
Scan Element | CIS |
Optical Resolution | 600 x 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 8-bit |
Colour Depth (Internal) | 16-bit |
Document & Media Handling | |
Max Original Size | 216 x 297 mm |
Supported Original Sizes | 216 x 297 mm |
Min Media Size | 89 x 127 mm |
Max Media Size | A4/Legal |
Min Media Weight | 64 g/m² |
Max Media Weight | 275 g/m² |
Supported Media Type | Plain paper, glossy photo paper, magnetic photo paper, restickable photo paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm, 130 x 130 mm, 215.9 x 676 mm |
Borderless Photo Sizes | 100 x 150 mm, 130 x 180 mm, 130 x 130 mm |
Document & Media Handling Details | Input tray - 60 sheets size: 89 x 127 mm - 215.9 x 676 mm weight: 64 g/m² - 275 g/m² |
Speed Details | Printing: up to 7.7 ipm - B/W , Printing: up to 4 ipm - colour , Printing: 65 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 3 ipm |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B |
Security Protocols & Features | WEP, WPA-PSK, WPA2-PSK |
Operating System Support | MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Chrome OS, iPadOS, macOS 10.12.6 - macOS 10.15 |
Software Included | Drivers & Utilities, MP Driver including Scanning Utility, Canon Easy-PhotoPrint Editor |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Operational | 9 Watt |
Power Consumption Standby | 0.8 Watt |
Miscellaneous | |
Direct Printing Specifications | PictBridge |
Consumables Included | 1 x ink cartridge (black) , 1 x ink cartridge (colour) |
Dimensions & Weight | |
Width | 43.5 cm |
Depth | 32.7 cm |
Height | 14.5 cm |
Weight | 4 kg |
Environmental Parameters | |
Sound Emission | 48 dBA (operating) |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Manufacturer Warranty | |
Service & Support | 2 Years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
