Canon PIXMA TS5050 Colour Inkjet Multifunction Printer
£90.30
24 in stock
Delivery:
Standard: 1-3 working days
Key features
  • The photo printer you've been looking for
  • Perfectly proportioned
  • Print wirelessly
  • Type: Printer / copier / scanner
  • Functionality: Copier, Printer, Scanner
  • Technology: Ink-jet
  • Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
  • Stock Status: In Stock
Product codes
High-quality colour printing from the comfort of your own home, with scan and copy functions, Wi-Fi, cloud connectivity and an easy-to-use 7.5 cm (3") LCD display - all contained within a compact, space-saving body.
The photo printer you've been looking for:
Print beautiful photographs and crisp text - over USB cable, Wi-Fi or directly from your SD cards. Canon's FINE inkjet print technology and 5 single inks bring convenience, cost savings and great-looking prints.
Perfectly proportioned:
Experience a lean, space-saving form factor 40% smaller than previous equivalent models. Clever contrasting textures, rounded corners and tapering contours make the printer's already-small frame appear even smaller. A superb printer inside and out - and an elegant addition to any desk or home office.
Print wirelessly:
Built-in Wi-Fi means you can print from your smartphone, tablet or computer via support for Mopria™ for Android, Apple AirPrint™, Google Cloud Print™, Windows 10 Mobile™ and the Canon PRINT app. Print your photos directly from Wi-Fi-enabled cameras, or using the built-in SD card slot.
So easy to use:
Every function is within easy reach with the manually adjustable front panel, 7.5 cm (3") LCD display and simple interface. The clear, simple buttons mean quick access to the printer's primary functions, whether printing, copying or scanning.
Access cloud services:
Using PIXMA Cloud Link, accessed through the Canon PRINT app on your smartphone or tablet, you can print from popular social network and cloud services including Facebook, Instagram, Google Drive, Dropbox, OneDrive and many more. You can even upload scanned documents and photos to Google Drive, OneDrive and Dropbox.
Economical printing:
Running costs won't break the bank, thanks to the optional high-capacity Canon XL ink cartridges, letting you save as much as 30% per page compared to standard equivalents. The 5 single ink cartridges mean you'll only need to replace the colour that has run out.
Unleash your creativity:
Get inspired with CREATIVE PARK and CREATIVE PARK PREMIUM*. Design and print greeting cards, calendars, photo collages and stunning 3D paper craft animals, toys and landmark buildings.
Square paper support:
Add new life to your social network snaps - access Instagram via PIXMA Cloud Link then print your favourite shots using Canon's 13x13 cm (5"x5") Photo Paper Plus Glossy II square media.
This model has replaced the PIXMA MG5750
Product Description Canon PIXMA TS5050 - multifunction printer - colour
Device Type Multifunction printer
Printing Technology Ink-jet (colour)
Inkjet Technology Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
Max Copying Speed 6 ppm (colour)
Max Printing Speed Up to 12.6 ipm (mono) / up to 9 ipm (colour)
Max Printing Resolution 4800 x 1200 dpi (colour)
Scanning 1200 x 2400 dpi
Display 3"
Original Size 216 x 297 mm (max)
Original Type Sheets
Media Size Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Envelopes, plain paper, photo paper, glossy photo paper, matte photo paper, high resolution paper, luster paper, semi-gloss photo paper
Standard Media Capacity 100 sheets
Connection Availability Yes
Interface USB 2.0, Wi-Fi(n)
AirPrint Enabled Yes
Office Machine Features PIXMA Cloud Link, access point mode
Power AC 120/230 V (50/60Hz)
Dimensions (WxDxH) 37.2 cm x 31.5 cm x 12.6 cm
Weight 5.5 kg
Enclosure Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon PIXMA TS5050 Col...
£90.30
