Affordable, connected home all-in-one for simple wireless color printing, copying and scanning from mobile devices.
Fun, affordable and user friendly, this compact, stylish family printer takes all the hassle out of creating beautiful images and documents at home - with smart wireless connectivity to your devices, social networks and cloud storage services. Enjoy control from different angles using the manual tilt panel with colour screen and simple to use button navigation.
Product Description | Canon PIXMA TS5150 - multifunction printer - colour | Device Type | Multifunction printer | Printing Technology | Ink-jet (colour) | Inkjet Technology | Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink | Max Printing Speed | Up to 13 ipm (mono) / up to 6.8 ipm (colour) | Max Printing Resolution | 4800 x 1200 dpi (colour) | Scanning | 1200 x 2400 dpi | Display | 2.5" | Original Size | 216 x 297 mm (max) | Original Type | Sheets | Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Envelopes, plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper | Standard Media Capacity | 120 sheets | Automatic Duplexing | Yes (printing) | Connection Availability | Yes | Interface | USB 2.0, Wi-Fi(n), Bluetooth LE | AirPrint Enabled | Yes | Office Machine Features | PIXMA Cloud Link, access point mode | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 42.5 cm x 31.5 cm x 14.7 cm | Weight | 6.5 kg | Enclosure Colour | Black | Manufacturer Warranty | 2 Years |
General | |
Printing Technology | Ink-jet - colour |
Display Diagonal Size | 2.5" |
Display Colour Support | Colour |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Copying Features | 2 on 1, 4 on 1, fit to page, ID Card Copy, Frame Erase Copy, Borderless copy |
Printing | |
Inkjet Technology | Canon FINE (Full-lithography inkjet Nozzle Engineering) |
Ink Cartridge Configuration | 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, black |
Colour | 4-ink |
Automatic Duplexing | Yes |
Colour Management Features | Mopria |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 2400 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 8-bit |
Colour Depth (Internal) | 16-bit |
Document & Media Handling | |
Max Original Size | 216 x 297 mm |
Max Media Size | A4/Legal |
Min Media Weight | 64 g/m² |
Max Media Weight | 300 g/m² |
Supported Media Type | Envelopes, plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm |
Supported Envelope Sizes | International DL (110 x 220 mm), Com-10 (105 x 241 mm) |
Borderless Photo Sizes | ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm |
Document & Media Handling Details | Input tray - 20 sheets size: 100 x 150 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m² , Paper cassette - 100 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 105 g/m² |
Speed Details | Printing: up to 13 ipm - B/W , Printing: up to 6.8 ipm - colour , Printing: 43 sec (10 x 15 cm (4"x6")) - photo , Scanning: 14 sec (A4) - colour |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B |
Security Protocols & Features | WEP, WPA-PSK, WPA2-PSK |
Operating System Support | MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Windows 10 Mobile, macOS 10.12, Apple Mac OS X 10.10.5 - 10.11 |
Software Included | Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Operational | 14 Watt |
Power Consumption Standby | 1.5 Watt |
Miscellaneous | |
Direct Printing Specifications | PictBridge |
Consumables Included | 1 x ink cartridge (yellow/cyan/magenta) , 1 x ink cartridge (black) |
Dimensions & Weight | |
Width | 42.5 cm |
Depth | 31.5 cm |
Height | 14.7 cm |
Weight | 6.5 kg |
Environmental Parameters | |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Manufacturer Warranty | |
Service & Support | 2 Years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
