Canon PowerShot SX700 HS Red Camera
Key features
  • 30x optical zoom (25-750mm) helps ensure outstanding optical performance and versatility
  • Built-in Wi-Fi allows wireless transferring of images and video to compatible mobile devices
  • The camera lets you remotely shoot using your smartphone or tablet
  • For easier Wi-Fi connectivity, built-in NFC (Near Field Communication) allows quick and simple pairing to a compatible Android device
  • 16.1 Megapixel High-Sensitivity CMOS sensor combined with the DIGIC 6 Image Processor helps provide excellent low-light performance
  • Capture stunning 1080p/60p Full HD video with a dedicated movie button
Product codes
The stylish and pocket-sized PowerShot SX700 HS camera features an impressive 30x optical zoom lens (equivalent to 25-750mm zoom range), built-in Wi-Fi, and Near Field Communication (NFC) capabilities helping to ensure high-quality images can be captured and easily shared. The 30x optical zoom PowerShot SX700 HS camera combines a 16.1 megapixel High-Sensitivity CMOS sensor and the DIGIC 6 Image Processor to create the Canon HS SYSTEM - allowing for excellent low-light performance. With Canon's Intelligent IS, the PowerShot SX700 HS camera automatically chooses from various settings to help optimize image stabilization for the shooting condition. The Wi-Fi connectivity options in the PowerShot SX700 HS camera allow users to easily share beautiful images online with family and friends. With NFC, users press the Mobile Device Connect Button and tap their NFC-enabled Android device to the PowerShot SX700 HS camera to send images from the camera to their compatible smartphone with ease.
No matter the situation, you can be confident that the PowerShot SX700 HS camera's genuine Canon 30x Optical Zoom will capture images with exceptional brilliance and clarity. Canon's innovative Intelligent IS system analyzes camera movement and applies the best shake correction method for the shooting situation - allowing you to focus on framing and capturing your shot. And Zoom Framing Assist delivers automatic tracking, so you can easily reframe long-zoom shots without losing your subject. Even the camera's easy-to-grip shape is specifically designed for a secure hold and steady shooting.
The PowerShot SX700 HS camera features a 16.1 Megapixel High-Sensitivity CMOS sensor to make even your everyday photography remarkable. The large sensor takes in more light, so images are clear and beautifully detailed. High ISO shots are particularly impressive, with less noise and expanded dynamic range. And the 16.1 Megapixel resolution gives you the flexibility to be more creative with your shots: crop and enlarge any part of an image - you can be confident that the detail and resolution you need are there.
In addition to its super-powerful 30x Optical Zoom, the PowerShot SX700 HS also turns out impressive artistic photos with Creative Shot mode. Rather than randomly applying filters, Creative Shot mode takes advantage of advanced Canon technologies to analyze the individual scene, subject and exposure to apply any of 46 filter options. In addition to the original shot, the camera automatically produces and saves five additional variations of the composition. Filter choices are grouped into Retro, Monochrome, Special and Natural categories to make exploring the world of artistic photography fun and easy, or simply select Auto to access the full range of effects. With Creative Shot mode, the result is stunning artistic photos that are perfect for sharing.
The PowerShot SX700 HS not only preserves your special video memories with spectacular realism and detail, but also does it in a format that makes them easy to share. You can simply press the dedicated movie button to start and stop video recording, so you're always ready to capture the moment as it happens. The camera records in stunningly realistic 1080p Full HD so even when played back on a big-screen HDTV, your videos are crystal clear, with smooth action and beautifully natural color. You can choose to record in 30 fps or 60 fps, so even fast-moving subjects are captured with crisp detail. And videos are recorded in MP4 format, perfectly sized for quick online sharing - whether you're showing relatives what the kids are up to or posting status updates on social networking sites.
Product Description Canon PowerShot SX700 HS - digital camera
Product Type Digital camera - compact
Memory Card Slot SD card
Image Processor DIGIC 6
Wireless Interface Wi-Fi, NFC
Sensor Resolution 16.1 Megapixel
Max Video Resolution 1920 x 1080
Lens System Zoom lens - 30x zoom - 4.5 - 135 mm - f/3.2-6.9
Focus Adjustment Automatic
Digital Zoom 4x
Image Stabiliser Optical (Intelligent IS with 5-axis Enhanced Dynamic Mode)
Camera Flash Pop-up flash
Display LCD display - 3"
Supported Battery Canon NB-6LH Li-ion rechargeable battery (included)
Interface Composite video/audio, HDMI, USB 2.0
Colour Red
Dimensions (WxDxH) 11.27 cm x 3.48 cm x 6.58 cm
Weight 269 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
