CoolerMaster 1000W Vanguard V1000W 80plus Gold Fully Modular PSU
£174.28
Delivery:
Key features
  • Fully modular cable design incorporates a single 1000W +12V output that delivers up to 83A
  • Silent 135 mm FDB fan for lower noise and longer lifespan
  • Eight PCI-E 6+2 pin connectors to support high-end GPUs
  • 100% high quality capacitor ensures performance and reliability
Product codes
Cooler Master developed the V-series to re-ascertain its position as the worlds top power supply brand. It features outstanding efficiency, especially at typical low idle loads, excellent hold up times, voltage stability and ripple suppression. It only uses highest grade Japanese capacitors, most of them solid capacitors, as well as a massive high quality 42mm transformer.
And thanks to high quality FDB fans V-series PSUs are extremely cool and quiet. The V-series uses a fully modular cable system with beautiful all black, extra slim flat-ribbon cables. This makes cable management a breeze and results in nice looking clean builds with the best possible airflow.
Product Description Cooler Master V Series V1000 - power supply - 1000 Watt
Device Type Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance ATX12V 2.31
80 PLUS Certification 80 PLUS Gold
Localisation United Kingdom
Input Voltage AC 115/230 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 1000 Watt
Input Connectors 1
Output connectors 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin +12V with detachable 4 pin section , 8 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 9 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System 135 mm fan
Dimensions (WxDxH) 15 cm x 17 cm x 8.6 cm
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
CoolerMaster 1000W Van...
£174.28
