CoolerMaster 550W GM Series G550M 80 Plus Bronze Modular PSU
Key features
  • Unique 3D circuit design offers high efficiency and improves the heat dissipation
  • Powerful single +12 V rail for superior load balancing and VGA compatibility
  • Modular cable designs for better cable management
  • Custom DC-DC module design offers higher efficiency and voltage stability
  • Haswell C6/C7 support and zero load operation
  • 80 PLUS Bronze certified: up to 88% efficiency at typical load
Product codes
The intelligent 120 mm fan speed controller with honey combo mesh increases airflow for better heat dissipation. The custom 12 V to 3.3 V and 5 V module design offers notably higher efficiency and voltage stability than other designs. It offers high efficiency, improves the heat dissipation and reduces the unnecessary cables which results in much lower crosstalk, signal noise.
Cooler Master GM Series - power supply - 550 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31
80 PLUS Certification
80 PLUS Bronze
Europe
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 1 x 4 PIN mini-power connector
15 cm x 14 cm x 8.6 cm
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
CoolerMaster 550W GM S...
