CoolerMaster 650W GM Series G650M 80 Plus Bronze Modular PSU
Key features
  • Unique 3D circuit design offers high efficiency and improves the heat dissipation
  • Powerful single +12 V rail for superior load balancing and VGA compatibility
  • Modular cable designs for better cable management
  • Custom DC-DC module design offers higher efficiency and voltage stability
  • Haswell C6/C7 support and zero load operation
Product codes
The intelligent 120 mm fan speed controller with honey combo mesh increases airflow for better heat dissipation. Only use the cables you need, no unnecessary cable mess! Building a clean and tidy system with excellent airflow has never been this easy and convenient. It offers high efficiency, improves the heat dissipation and reduces the unnecessary cables which results in much lower crosstalk, signal noise.
Cooler Master GM Series - power supply - 650 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31
80 PLUS Certification
80 PLUS Bronze
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 8 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
15 cm x 14 cm x 8.6 cm
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
CoolerMaster 650W GM S...
