CoolerMaster 850W Vanguard V850W 80plus Gold Fully Modular PSU
£149.29
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fully modular cable design incorporates a single 1000W +12V output that delivers up to 83A
  • Silent 135 mm FDB fan for lower noise and longer lifespan
  • Eight PCI-E 6+2 pin connectors to support high-end GPUs
  • 100% high quality capacitor ensures performance and reliability
Product codes
Cooler Master developed the V-series to re-ascertain its position as the worlds top power supply brand. It features outstanding efficiency, especially at typical low idle loads, excellent hold up times, voltage stability and ripple suppression. It only uses highest grade Japanese capacitors, most of them solid capacitors, as well as a massive high quality 42mm transformer.
And thanks to high quality FDB fans V-series PSUs are extremely cool and quiet. The V-series uses a fully modular cable system with beautiful all black, extra slim flat-ribbon cables. This makes cable management a breeze and results in nice looking clean builds with the best possible airflow.
Cooler Master V Series V850 - power supply - 850 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31
80 PLUS Certification
80 PLUS Gold
United Kingdom
Input Voltage
AC 115/230 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Input Connectors
1
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 6 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 9 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
135 mm fan
15 cm x 17 cm x 8.6 cm
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
CoolerMaster 850W Vang...
£149.29
