CoolerMaster Cooler Hyper 612 V2 Fan CPU Cooler
Key features
  • Hyper 612 ver. 2 generates only max 20 dB to provide a good operating environment
  • Without fans, the big fin area will give you dissipation for passive usage
  • Adopts the innovative patented CDC (Continuous Direct Contact) technology - side-by-side heat pipe configurations with no gaps creating a smooth surface for heat conduction
  • Folding fin design with good air guiding ensuring high efficiency heat dissipation
  • Quick-snap fan bracket design for simple installation
Product codes
Cooler Master Hyper 612 Ver. 2 - Processor cooler - ( LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket ) - aluminium with copper base - 120 mm
Product Description Cooler Master Hyper 612 Ver. 2 processor cooler
Product Type Processor cooler
Compatibility LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket
Heatsink Material Aluminium with copper base
Fan Diameter 120 mm
Fan Height 25 mm
Fan Bearing Rifle bearing
Rotation Speed 800-1300 rpm
Air Flow 26.6 - 44.2 cfm
Noise Level 11 - 20 dBA
Power Connector 4-pin fan connector
Rated Voltage 12 V
Features Pulse-width modulation (PWM) support, 6 copper heatpipes (6 mm), Continuous Direct Contact (CDC) technology, X-Vent technology
Dimensions (WxDxH) 12.89 cm x 15.01 cm x 16.04 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
CoolerMaster Cooler Hy...
