CoolerMaster Elite 130 USB 3.0 High Airflow Mini-ITX Case
£45.62
Delivery:
Key features
  • Unprecedented airflow for a Mini-ITX case with front mesh panel and vents on the top and side panels
  • Dual SuperSpeed USB 3.0
  • Supports a 120 mm radiator in the front
  • Supports standard length ATX PSU
  • Supports ultra high-end graphics card up to 343 mm/13.5 inch
  • Case Form Factor: Ultra small form factor
  • Motherboard Form Factor: Mini ITX
  • Colour: Black
Product codes
The Elite 130 is an ultra compact case with support for full size high-end desktop components. It can accommodate the largest high-end VGAs, a 5.25" optical drive and up to 3 HDDs/5 SSDs. You can even install a 120 mm radiator in the front for extreme cooling. Thanks to a smart airflow system featuring 2 fans and the full mesh front panel it manages to still keep the system extremely cool.
Product Description Cooler Master Elite 130 - ultra small form factor - mini ITX
Product Type System cabinet
Form Factor Ultra small form factor
Colour Black
I/O Connectors 2 x USB 3.0 , 1 x USB 2.0 , 1 x microphone , 1 x audio line-out/headphones
Supported Motherboards Mini-ITX
System Cabinet Features Supports 120 mm radiator in front panel
Power Device No power supply
Specification Compliance ATX / PS/2
Dimensions (WxDxH) 24 cm x 37.75 cm x 20.5 cm
Weight 3.1 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
CoolerMaster Elite 130...
£45.62
