CoolerMaster Hyper 103 3 Heatpipe 1x92mm PWM Blue LED Fan Tow...
CoolerMaster Hyper 103 3 Heatpipe 1x92mm PWM Blue LED Fan Tower CPUCooler
Key features
  • Cooler Master exclusive X-Vent and Air-Guide technology optimize the air flow toward heatpipes and ultimately reduce CPU temperature
  • 3 direct Contact heatpipes with stylish aluminum fins to provide excellent heat dissipation
  • 92 mm wide range PWM blue LED fan, RPM can be fine tuned for maximum airflow or whisper quiet operation
  • Tool-free mounting system for trouble-less installation
Product codes
The Hyper 103 is an affordable mainstream heatsink that delivers great cooling performance. Air flow is optimized towards heatpipes thanks to a special fin design and exclusive X-Vent and Air-Guide technology. A 92 mm PWM fan has a wide speed range. This low profile tower heatsink is a great match for all modern small form factor systems.
Cooler Master Hyper 103 RR-H103-22PB-R1 processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Long life sleeve bearing
Rotation Speed
800-2200 rpm
Air Flow
15.7-43.1 cfm
Noise Level
17 - 30 dBA
Power Connector
4-pin fan connector
Blue LEDs, heat pipe technology, Versatile Tool-free Multiplatform System (V.T.M.S.), X-Vent technology, Air-Guide technology
500 g
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
CoolerMaster Hyper 103...
