CoolerMaster Hyper 212 Evo - 4 Heatpipe, Tower CPU Cooler
£33.43
18 left in stock
Delivery:
Standard: 1-3 working days
Key features
  • Well-balanced cooling performance provides fin optimizations with perfect balance between high and low speed operations
  • 4 Direct Contact heat pipes with the patented CDC (Continuous Direct Contact) technology - creating a perfect, sleek surface for heat conduction
  • Wide-range PWM fan with unique wave-shaped blade design for excellent airflow
Product codes
The Hyper 212 EVO cooling systems are designed and optimized to provide the best user experience and cooling potential for a new generation of processors. The Hyper 212 EVO now features four Cooler Master patented Continuous Direct Contact (CDC) heat pipes that are tightly packed into a flat array on the CPU Cooler base. This acts as a virtual vapor chamber that dissipates a large amount of heat. The aluminum fin structure has been optimized to provide the perfect performance balance between high and low speed fan operations
Cooler Master Hyper 212 Evo - processor cooler
Processor cooler
Compatibility
LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, LGA1150 Socket
Heatsink Material
Aluminium
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Long life sleeve bearing
Rotation Speed
600-1600 rpm
Air Flow
24.9-66.3 cfm
Noise Level
9 - 31 dBA
Power Connector
4-pin fan connector
Heat pipe technology, Pulse-width modulation (PWM) support
8 cm x 12 cm x 15.9 cm
0.58 kg
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
CoolerMaster Hyper 212...
£33.43
