CoolerMaster Hyper 212x 4 Heatpipe 1x 120 Pwm Fan Tower Cpu C...
CoolerMaster Hyper 212x 4 Heatpipe 1x 120 Pwm Fan Tower Cpu Cooler
£33.68
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Vents are placed at a 45-degree angle around each heat pipe
  • Funnel-shaped aluminum fins and a series of perforated dimples guide the airflow towards the heat pipes
  • Several continuous direct-contact heat pipes create a gapless contact surface
  • Aluminum fin array with tunnel effect creates micro vortices that boost the airflow and circulate it around the heat pipes
  • Type: CPU Cooler
  • Stock Status: In Stock
Product codes
The Hyper 212X features a PWM-controlled fan and provides incredibly low noise level. Amazing CDC and X-Vent technologies, funnel-shaped aluminum fins and a series of perforated dimples create a CPU cooler that is optimized for great heat dissipation. The universal bracket design ensures easy and worry-free installation on every platform.
Product Description Cooler Master Hyper 212X processor cooler
Product Type Processor cooler
Compatibility LGA1156 Socket, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket, LGA1151 Socket
Heatsink Material Aluminium
Fan Diameter 120 mm
Fan Height 25 mm
Fan Bearing Rifle bearing
Rotation Speed 600-1700 rpm
Air Flow 24.9-82.9 cfm
Noise Level 9 - 27.2 dBA
Power Connector 4-pin fan connector
Rated Voltage 12 V
Features Heat pipe technology, Pulse-width modulation (PWM) support, 4 copper heatpipes (6 mm), Continuous Direct Contact (CDC) technology, X-Vent technology
Dimensions (WxDxH) 7.9 cm x 12 cm x 15.8 cm
Localisation Europe
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
CoolerMaster Hyper 212...
£33.68
