CoolerMaster Hyper TX3 Evo - 3 Heatpipe, Tower CPU Cooler
Key features
  • 3 direct contact heat pipes with a base that is engineered to minimize CPU contact gaps - providing excellent heat conduction
  • Option for adding 2nd fan with quick-snap fan brackets to increase cooling performance
  • A mere 17 dBA (minimum speed) is accomplished by utilizing a silent 92mm PWM fan with a wide RPM range
  • Versatile all-in-one mounting solution supporting Intel LGA 1366 / 1155 and AMD FM1 / AM3+
  • Excellent airflow design with compact heat sink dimension
Product codes
The Hyper TX3 EVO cooling system is designed and optimized to provide the best user experience and cooling potential for a new generation of processors.Optimized for current and future generation sockets, the Hyper TX3 EVO sees improvement in its Direct Contact heat pipe performance, expanded socket support, and a higher quality 92mm wide-range PWM fan.
Cooler Master Hyper TX3 EVO processor cooler
Processor cooler
Compatibility
LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA1151 Socket, Socket AM4
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Long life sleeve bearing
Rotation Speed
800-2200 rpm
Air Flow
15.7-43.1 cfm
Noise Level
17 - 30 dBA
Power Connector
4-pin fan connector
Heat-pipe Direct Touch (H.D.T.) Technology, Pulse-width modulation (PWM) support
7.9 cm x 9 cm x 13.6 cm
386 g
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
CoolerMaster Hyper TX3...
