CoolerMaster Nepton 280L, 280 x 30mm Radiator, 2 x 140 Jetflo...
CoolerMaster Nepton 280L, 280 x 30mm Radiator, 2 x 140 Jetflo CPU Cooler
Key features
  • CM exclusive designed
  • Robust and extra thick FEP tubing
  • UltraFine microchannel
  • Advanced fan blade design
Product codes
The Nepton 280L is Cooler Master's watercooling kit that aims to bring watercooling to the next level. Nepton 280L is using a CM exclusive designed pump with a highly effective water block. It has thicker and longer tubing for upgraded performance. In addition, dual JetFlo 140 fans + an extra large 280 mm radiator provide substantial cooling power with over 300 W heat dissipation, which enables users to overclock their CPU and maximize performance.
Product Description Cooler Master Nepton 280L liquid cooling system radiator
Product Type Liquid cooling system radiator
Built-in Devices Cooling fan
Compatibility LGA775 Socket, LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket
Fan Diameter 140 mm
Fan Height 25 mm
Fan Bearing Rifle bearing
Rotation Speed 800-2000 rpm
Air Flow 54.3-122.5 cfm
Noise Level 21 - 39 dBA
Power Connector 4-pin fan connector
Rated Voltage 12 V
Product Material Aluminium
Dimensions (WxDxH) 7.5 cm x 6.98 cm x 4.91 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
CoolerMaster Nepton 28...
