CoolerMaster SickleFlow 120 Blue LED Fan - 120mm, 2000RPM
Key features
  • Up to 69CFM (maximum RPM)
  • 19 dB-A silent application for CPU cooling
  • RoHS compliance for protecting the environment
  • 50,000 long life hours
Product codes
R4 series fans offer a unity of maximum rotational speed and optimum airflow. Using a unique long-life sleeve bearing fan, the R4 series offers long life rating of 50,000 hours. R4 series fans perform at a maximum of 69CFM at 2000RPM.
Product Description Cooler Master R4-L2R-20AC-GP case fan
Product Type Case fan
Package Content Screws, 3-pin plug to 4-pin Molex adapter
Fan Diameter 120 mm
Fan Height 25 mm
Fan Bearing Long life sleeve bearing
Rotation Speed 2000 rpm
Air Flow 69 cfm
Power Connector 3-pin plug, 4 pin Molex connector
Features Blue LEDs
Dimensions (WxDxH) 12 cm x 12 cm x 2.5 cm
Weight 116 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
CoolerMaster SickleFlo...
