CoolerMaster Silencio 352 Black Matt Edition USB3 MicroATX Mi...
CoolerMaster Silencio 352 Black Matt Edition USB3 MicroATX Mini-ITX Case
£64.59
Delivery:
Key features
  • Matte front panel for an elegant look
  • Two powerful XtraFlo fans in the front and rear for optimized airflow
  • Liquid cooling ready for professionals and enthusiasts - supports a 240 mm radiator in the front or a 120 mm radiator in the rear
  • Dual Super Speed USB 3.0 and SD card reader
  • Supports a CPU cooler up to 155 mm/6.1-inch tall and high-end graphics cards up to 355 mm/14.0-inch long
  • Great expandability with the support of up to 4 SSDs and 3 HDDs
  • Multiple dust filters (top, bottom, front) for improved system maintenance
  • Case Form Factor: Mid tower
  • Motherboard Form Factor: Mini ITX / micro ATX
  • Colour: Midnight black
Product codes
Silencio 352 is the 1st microATX case with noise canceling foam lined front door and side panels from Cooler Master.
Product Description Cooler Master Silencio 352 - mid tower - mini ITX / micro ATX
Product Type System cabinet
Form Factor Mid tower
Colour Midnight black
Built-in Devices Card reader
I/O Connectors 2 x USB 3.0 , 1 x USB 2.0 , 1 x microphone , 1 x audio line-out/headphones
Supported Motherboards microATX, Mini-ITX
System Cabinet Features Front panel door, top panel dust filter, removable dust filter, front dust filter, floor dust filter, detachable top cover, supports 240 mm radiator in front panel, supports 120 mm radiator in rear, side panel sound-damping foam mats
Power Device No power supply
Specification Compliance ATX / PS/2
Dimensions (WxDxH) 20 cm x 45.3 cm x 37.8 cm
Weight 4.7 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
CoolerMaster Silencio...
£64.59
