CoolerMaster Silencio 452 ATX USB 3.0 SD Card Reader ATX Case
£73.12
Delivery:
Key features
  • The matte front door and side panels are equipped with noise absorbing materials for extreme silence
  • Two pre-installed 120 mm fans in the front and rear for optimized airflow
  • Liquid cooling ready for professionals and enthusiasts - supports 240 mm radiators in the front or 120 mm radiators in the rear
  • Dual Super Speed USB 3.0 and SD card reader
  • Supports CPU coolers up to 158 mm/6.2 inch tall and high-end graphics cards up to 386 mm/15.2 inch long
  • Great expandability with the support of up to 6 HDDs and 2 SSDs
  • Multiple dust filters (front, bottom) for improved system maintenance
  • Case Form Factor: Mid tower
  • Motherboard Form Factor: ATX
  • Colour: Midnight black
Product codes
The matte front door and side panels of the cabinet are equipped with noise absorbing materials for extreme silence. There are two pre-installed fans in the front and rear for optimized airflow, Moreover, the Cooler Master Silencio 452 provides liquid cooling ready for professionals and enthusiasts.
Product Description Cooler Master Silencio 452 - mid tower - ATX
Product Type System cabinet
Form Factor Mid tower
Colour Midnight black
Built-in Devices Card reader
I/O Connectors 2 x USB 3.0 , 1 x USB 2.0 , 1 x microphone , 1 x audio line-out
Supported Motherboards ATX, microATX
System Cabinet Features Front panel door, removable HDD rack, front dust filter, supports 240 mm radiator in front panel, supports 120 mm radiator in rear, side panel sound-damping foam mats, bottom dust filter
Power Device No power supply
Dimensions (WxDxH) 19 cm x 49.7 cm x 44.9 cm
Weight 6.14 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
CoolerMaster Silencio...
£73.12
