Corsair 1200W HX Series HX1200 80 Plus Platinum Fully Modular...
Corsair 1200W HX Series HX1200 80 Plus Platinum Fully Modular PSU
£235.46
Delivery:
Key features
  • Quiet, efficient operation
  • 100% Japanese 105 °C capacitors
  • Zero RPM fan mode
  • Power in your hands
  • Easy installation
Product codes
CORSAIR HX series power supplies give you extremely tight voltage regulation, quiet operation, Platinum-certified efficiency, and a fully modular cable set. Built with all Japanese 105°C capacitors, they're a great choice for high performance PCs where reliability is essential.
Product Description CORSAIR HX Series HX1200 - power supply - 1200 Watt
Device Type Power supply - internal
Specification Compliance ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification 80 PLUS Platinum
Weight 2.3 kg
Localisation United Kingdom
Input Voltage AC 100-240 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 1200 Watt
Output connectors 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 8 x 8 pin PCI Express power with detachable 2 pin section , 8 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System 135 mm fan
Included Accessories Case badge, cable ties, mounting kit
Dimensions (WxDxH) 15 cm x 20 cm x 8.6 cm
Manufacturer Warranty 10 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair 1200W HX Serie...
£235.46
