Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
| Product Description | CORSAIR Vengeance - DDR3 - kit - 16 GB: 4 x 4 GB - DIMM 240-pin - 1866 MHz / PC3-15000 - unbuffered | Product Type | Memory kit | Capacity | 16 GB: 4 x 4 GB | Memory Type | DDR3 SDRAM - DIMM 240-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 1866 MHz (PC3-15000) | Latency Timings | CL9 (9-10-9-27) | Features | Dual channel, Intel Extreme Memory Profiles (XMP 1.3), Vengeance low profile heatspreader, quad channel, unbuffered | Voltage | 1.5 V | Manufacturer Warranty | Limited lifetime warranty |
General | |
Memory | |
| Type | DRAM memory kit |
| Technology | DDR3 SDRAM |
| Form Factor | DIMM 240-pin |
| Voltage | 1.5 V |
Expansion / Connectivity | |
| Compatible Slots | 4 x memory - DIMM 240-pin |
Manufacturer Warranty | |
| Service & Support | Limited lifetime warranty |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
