Corsair 1GB (1x1GB) DDR1 400Mhz CL3 Value Select 184 Pin Des...
Corsair 1GB (1x1GB) DDR1 400Mhz CL3 Value Select  184 Pin Desktop Memory Module
Key features
  • Individually tested
  • Superior hardware design to reduce heat generation
Product codes
Corsair Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop systems.
CORSAIR Value Select - DDR - 1 GB - DIMM 184-PIN - unbuffered
RAM memory
1 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
400 MHz (PC3200)
Latency Timings
CL3
Unbuffered
ASUS P4P800; Chaintech 7KJD; ECS 661, 755, 848, 865, 915, K8M800, K8T800, KM400, KT600, KV1, KV2, N2U400, P4IBAD2, PM800, PT800; FIC VC37; PCCHIPS M906, M909, M952, M963; Shuttle SB51, SB52, SB62, SB65, SB75, SB81, SN41, SN45, SN85, SN95; SOYO SY-P4I865, P4I875, P4RS350; SUPERMICRO SUPER P4SCT
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Corsair 1GB (1x1GB) DD...
