Corsair 1GB (1x1GB) DDR1 667Mhz CL5 Value Select SODIMM 200...
Corsair 1GB (1x1GB) DDR1 667Mhz CL5 Value Select SODIMM  200 Pin Notebook Memory Module
Key features
  • Individually tested
  • Superior hardware design to reduce heat generation
Product codes
Corsair Value Select line provides quality, tested, compatible desktop and notebook memory at competitive prices. The Value Select line is qualified for major current desktop and notebook systems.
Product Description CORSAIR Value Select - DDR2 - module - 1 GB - SO-DIMM 200-pin - 667 MHz / PC2-5300 - unbuffered
Product Type Memory module
Capacity 1 GB
Memory Type DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 667 MHz (PC2-5300)
Features Unbuffered
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
