Corsair 256GB Flash Voyager USB 3.0 Drive
£47.60
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fast USB 3.0 connectivity
  • Durable rubber housing
  • Water resistant
  • Shock proof
  • Backward compatible with USB 2.0
  • Plug and Play compatible
Product codes
USB 3.0 speed. USB 2.0 compatibility. Flash Voyager durability.
As fast as USB flash drives are, copying files always seems to take a little longer than you'd like. The advent of the USB 3.0 interface puts an end to that. You can move files back and forth in a fraction of the time it takes with standard USB 2.0 flash drives, and the proprietary water-resistant rubber housing helps keep those files safe.
USB 2.0 compatible
Of course, Flash Voyager USB 3.0 is backward compatible with USB 2.0. Even if you haven't yet upgraded your PC to USB 3.0, it's still a great choice for convenient, reliable portable file management, and the additional performance will be ready when your PC is.
Durable and shock-resistant
The finger-friendly ergonomics of the Flash Voyager USB 3.0 will make it the USB flash drive that you'll want to take with you everywhere. Reliability is essential.
Corsair's proprietary all-rubber housing is extremely durable, for worry-free transport of your valuable data. And because accidents happen, Flash Voyager USB 3.0 is water-resistant.
Unlike traditional storage media, flash drives are solid-state, so they can easily handle the everyday — and not so everyday — drops and bumps that come with the territory.
Convenient and compatible
It works with Microsoft® Windows®, Mac OS X® and even Linux without drivers, and there's no software to install — just plug it in, and go. If your computer has a USB 2.0 or USB 3.0 connector, you can use Flash Voyager USB 3.0.
Corsair Flash Voyager USB 3.0 - USB flash drive - 256 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
256 GB
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair 256GB Flash Vo...
£47.60
