Corsair 256GB Flash Voyager USB 3.0 Drive
£44.02
25 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fast USB 3.0 connectivity
  • Durable rubber housing
  • Water resistant
  • Shock proof
  • Backward compatible with USB 2.0
  • Plug and Play compatible
  • Capacity: 256GB
  • Interface: USB 3.0
  • Stock Status: In Stock
Product codes
USB 3.0 speed. USB 2.0 compatibility. Flash Voyager durability.
As fast as USB flash drives are, copying files always seems to take a little longer than you'd like. The advent of the USB 3.0 interface puts an end to that. You can move files back and forth in a fraction of the time it takes with standard USB 2.0 flash drives, and the proprietary water-resistant rubber housing helps keep those files safe.
USB 2.0 compatible
Of course, Flash Voyager USB 3.0 is backward compatible with USB 2.0. Even if you haven't yet upgraded your PC to USB 3.0, it's still a great choice for convenient, reliable portable file management, and the additional performance will be ready when your PC is.
Durable and shock-resistant
The finger-friendly ergonomics of the Flash Voyager USB 3.0 will make it the USB flash drive that you'll want to take with you everywhere. Reliability is essential.
Corsair's proprietary all-rubber housing is extremely durable, for worry-free transport of your valuable data. And because accidents happen, Flash Voyager USB 3.0 is water-resistant.
Unlike traditional storage media, flash drives are solid-state, so they can easily handle the everyday — and not so everyday — drops and bumps that come with the territory.
Convenient and compatible
It works with Microsoft® Windows®, Mac OS X® and even Linux without drivers, and there's no software to install — just plug it in, and go. If your computer has a USB 2.0 or USB 3.0 connector, you can use Flash Voyager USB 3.0.
Product Description CORSAIR Flash Voyager USB 3.0 - USB flash drive - 256 GB
Product Type USB flash drive
Interface Type USB 3.0
Storage Capacity 256 GB
OS Required Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair 256GB Flash Vo...
£44.02
