Corsair 32GB (2 x 16GB) Vengeance DDR4 DRAM 2400MHz C16 Kit B...
Corsair 32GB (2 x 16GB) Vengeance DDR4 DRAM 2400MHz C16 Kit Black
Key features
  • Great looking, great overclocking memory
  • Optimized for compatibility with the CPUs and motherboards
  • Next-generation density for the ultimate power user
Product codes
Vengeance Low Profile heat spreaders have a reduced height of 1.03". They're designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or any other space-constrained application where you need high-performance memory but standard Vengeance modules might not fit.
Product Description CORSAIR Vengeance LPX - DDR4 - 32 GB: 2 x 16 GB - DIMM 288-pin - unbuffered
Product Type RAM memory
Capacity 32 GB: 2 x 16 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 2400 MHz (PC4-19200)
Latency Timings CL16 (16-16-16-39)
Features Dual channel, 8 Layers PCB heatspreader, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), Vengeance LPX low profile heatspreader, unbuffered
Voltage 1.2 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Corsair 32GB (2 x 16GB...
