Corsair 32GB (4 x 8GB) Vengeance DDR3 1600MHz DIMM 240-pin CL10
Key features
  • Great looking, great overclocking memory
  • Optimized for compatibility with the CPUs and motherboards
  • Next-generation density for the ultimate power user
Product codes
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
CORSAIR Vengeance - DDR3 - 32 GB: 4 x 8 GB - DIMM 240-pin - unbuffered
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL10 (10-10-10-27)
Aluminium heat spreader, dual channel, Vengeance heatspreader, Intel Extreme Memory Profiles (XMP 1.3), quad channel, unbuffered
Voltage
1.5 V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair 32GB (4 x 8GB)...
