Your files are important - that's why you're taking them with you. Flash Survivor Stealth USB 3.0 flash drives help keep them safe. The anodized, aircraft-grade aluminum housing is waterproof to 200 meters, vibration-resistant, and shock-resistant.
Product Description | CORSAIR Flash Survivor Stealth - USB flash drive - 32 GB | Product Type | USB flash drive | Interface Type | USB 3.0 | Storage Capacity | 32 GB | OS Required | Apple MacOS 9.x or later, Linux Kernel 2.4.2 or later, Microsoft Windows 2000/ME/XP/Vista/7 | Manufacturer Warranty | 5-year warranty |
General | |
Compatibility | Non-specific |
Memory | |
Features | Shockproof, waterproof, vibration-proof, aircraft-grade aluminium housing |
Miscellaneous | |
Compliant Standards | Plug and Play |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Weight | 36.3 g |
