Beautifully simple and engineered to perform: the Crystal 460X has two-panel tempered glass, Direct Airflow cooling technology, is compact, expandable, and with RGB fans, is not afraid of the spotlight.
Product Description | CORSAIR Crystal Series 460X RGB - mid tower - ATX | Product Type | System cabinet | Form Factor | Mid tower | Colour | Black | I/O Connectors | 2 x USB 3.0 , 1 x headphones , 1 x microphone | Supported Motherboards | ATX, microATX, Mini-ITX | System Cabinet Features | Front dust filter, Direct Airflow Path design, tool-free drive holder, Liquid Cooling Ready, supports 120/240/280/360 mm radiator in front panel | Power Device | No power supply | Specification Compliance | ATX | Dimensions (WxDxH) | 22 cm x 44 cm x 46.4 cm | Weight | 7.97 kg | Manufacturer Warranty | 2-year warranty |
General | |
Max Mainboard Size | ATX |
Internal Bays Qty | 5 |
Product Material | Steel, tempered glass |
Colour | Black |
Cooling System | Front: 120 mm fan x 3 / intake / 2 x 140 mm fan supported , Top: 120/140 mm fan mount x 2 , Rear: 120 mm fan mount x 1 |
CPU Cooler Max Height | 170 mm |
Video Card Max Length | 370 mm |
Power Supply Max Length | 220 mm |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 2 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5" |
Expansion Slots | 7 |
Interfaces | 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack |
Power | |
Dimensions & Weight | |
Width | 22 cm |
Depth | 44 cm |
Height | 46.4 cm |
Weight | 7.97 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
