Corsair 4GB (1 x 4GB) Value DDR3 1600MHz 240-pin DIMM CL11
£17.52
Delivery:
Standard: 1-3 working days
Key features
  • Guaranteed to work on all dual and triple channel Intel and AMD platforms
  • World famous Corsair reliability and performance
  • Type: DDR3 SDRAM
  • Capacity: 4GB
  • Connection: DIMM 240-pin
  • Speed: 1600MHz
  • Data Integrity: Non-ECC
Product codes
The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
Product Description CORSAIR Value Select - DDR3 - 4 GB - DIMM 240-pin - unbuffered
Product Type RAM memory
Capacity 4 GB
Memory Type DDR3 SDRAM - DIMM 240-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 1600 MHz (PC3-12800)
Latency Timings CL11 (11-11-11-30)
Features Unbuffered
Voltage 1.5 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair 4GB (1 x 4GB)...
£17.52
