Corsair 4GB (1x4GB) DDR3 1600Mhz CL9 Vengeance SODIMM Perfor...
Corsair 4GB (1x4GB) DDR3 1600Mhz CL9 Vengeance SODIMM  Performance Notebook Memory Module
Key features
  • Great looking, great overclocking memory
  • Optimized for compatibility with the CPUs and motherboards
  • Next-generation density for the ultimate power user
Product codes
CORSAIR high performance Vengeance SODIMM memory module, 4GB (1x4GB) 1600MHz 9-9-9-24, 1.5V, allows you to automatically boost performance of your without bios reconfiguration. Slim and attractive design to ensure physical compatibility with all 2nd Generation Intel Core™ i5 and i7 notebooks. Each module is built using carefully selected DRAM to allow excellent stability and is backed by Corsair's limited lifetime warrany.
Key Features
  • 4GB (1x4GB) DDR3 SODIMM for 2nd Generation Intel Core™ i5 and i7 notebooks.
  • 1600MHz
  • 9-9-9-24 latency
  • 1.5V
  • Auto-overclocking (no bios configuration required)
  • Limited Lifetime Warranty
  • Density: 4GB (1x4GB Module)
  • Speed: 1600MHz
  • Timing: 9-9-9-24
  • Type: DDR3
  • Format: SODIMM
  • Pin Out: 204 Pin
  • Voltage: 1.5V
  • Note: if two modules are used both should be the same speed and timings
Product Description CORSAIR Vengeance - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
Product Type Memory module
Capacity 4 GB
Memory Type DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 1600 MHz (PC3-12800)
Latency Timings CL9 (9-9-9-24)
Features Intel Extreme Memory Profiles (XMP), unbuffered
Voltage 1.5 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
