Corsair 750 Watt Builder Series CX 750 Modular Power Supply
£98.55
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Up to 85% energy efficiency means less heat generation and lower energy bills
  • 0.99 active power factor corrections provides clean and reliable power universal AC input from 90-264 V
  • A dedicated single +12 V rail offers maximum compatibility with the latest components
  • Over-voltage and over-power protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components
  • Extra long fully-sleeved cables support full tower chassis
  • ErP lot 6 compliant
  • Power Rating: 750Watt
  • Stock Status: In Stock
Product codes
CX Series modular power supply units are an excellent choice for basic system builds and desktop PC computer upgrades, offering high reliability, low noise, and easy installation. The flexible modular cabling system lets you use only the cables you need, and 80 PLUS Bronze certified efficiency means less excess heat, lower noise, and lower power bills. The large-diameter, thermally controlled fan makes the CX Series modular quieter at idle, and the large diameter reduces noise even when you're pushing your system hard. And, the matte finish, sleeved cables and connectors help give your system a restrained, high-tech look.
Product Description CORSAIR CX-M Series CX750M - 2015 Edition - power supply - 750 Watt
Device Type Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance ATX12V 2.3/ EPS12V 2.91
80 PLUS Certification 80 PLUS Bronze
Weight 3.27 kg
Localisation United Kingdom
Input Voltage AC 100-240 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 750 Watt
Output connectors 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 8 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 2 x 4 PIN mini-power connector
Cooling System 135 mm fan
Colour Matte black
Dimensions (WxDxH) 15 cm x 16 cm x 8.6 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair 750 Watt Build...
£98.55
