Corsair 750W RM750X 80+ Gold Modular PSU
£109.56
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 80 PLUS Gold certified
  • Japanese 105°C capacitors
  • Zero RPM fan mode
  • Fully modular cable set
  • Power Rating: 750Watt
  • Stock Status: In Stock
Product codes
Corsair RMx series power supplies give you extremely tight voltage control, quiet operation, Gold-certified efficiency, and a fully modular cable set. Built with all Japanese 105°C capacitors, they're a great choice for high performance PCs where reliability is essential. 80 PLUS Gold efficiency reduces operating cost and excess heat, and Zero RPM fan mode ensures virtual silence at low and medium loads. And, the fully modular DC cables make builds and upgrades easy, with clean, great-looking results.
Product Description CORSAIR RMx Series RM750x - power supply - 750 Watt
Device Type Power supply - internal
Specification Compliance ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification 80 PLUS Gold
Weight 1.94 kg
Localisation United Kingdom
Input Voltage AC 100-240 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 750 Watt
Output connectors 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 7 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 4 x 8 pin PCI Express power with detachable 2 pin section
Cooling System 135 mm fan
Included Accessories Cable ties
Colour White
Dimensions (WxDxH) 15 cm x 18 cm x 8.6 cm
Manufacturer Warranty 10 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair 750W RM750X 80...
£109.56
