Corsair 850W CS850M Modular Series 850 Watt ATX 80 PLUS Gold PSU
Key features
  • 80 PLUS Gold-certified efficiency
  • Modular cabling with clearly marked connectors
  • Supports 4th Generation Intel Core processors
Product codes
CS Series Modular power supplies are ideal for basic desktop systems where low energy use, low noise, and simple installation are essential. 80 PLUS Gold efficiency reduces operating cost and excess heat. Flat, sleeved black modular cables with clearly-marked connectors make installation fast and straightforward, with good-looking results.
  • Modular cabling system lets you use only the cables you need
  • 850W Continuous power with 80 PLUS Gold certified efficiency for low noise and lower power bills
  • Built and tested to strict standards for trouble-free installation and smooth operation
  • Over-voltage and over-power protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components.
  • Extra long fully-sleeved cables support full tower chassis.
Box Contains
1 x CS850W PSU and Cables
Product Description CORSAIR CS Series CS850M - power supply - 850 Watt
Device Type Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification 80 PLUS Gold
Weight 2.475 kg
Localisation United Kingdom
Input Voltage AC 100-240 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 850 Watt
Output connectors 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 8 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector , 4 x 8 pin PCI Express power with detachable 2 pin section
Cooling System 120 mm fan
Dimensions (WxDxH) 15 cm x 16 cm x 8.6 cm
Manufacturer Warranty 3 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair 850W CS850M Mo...
