Corsair 850W HX850i High Performance 80+ Platinum Digital PSU
£168.49
Delivery:
Key features
  • Corsair Link Integration for monitoring performance and adjustment of fan speed and multi-rail/single rail mode
  • 80 PLUS Platinum efficiency, delivering 92% energy efficiency at real world load conditions
  • ZeroRPM mode for fanless operation at low loads and outstanding noise reduction
  • 140 mm thermally controlled fluid dynamic bearing fan spins up as needed
  • Fully Modular low profile cables for easy installation, less clutter, and helps maximize airflow through your computer's chassis
  • Fan self-test switch to determine fan functionality even before installation
  • Over-voltage protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components
  • Power Rating: 850Watt
Product codes
HXi Series power supplies give you extremely tight voltage control, virtually silent operation, and a fully modular cable set. With all Japanese 105°c capacitors, they're a great choice for high performance PCs where reliability is essential. 80 PLUS Platinum efficiency reduces operating cost and excess heat, and together with Zero RPM Fan Mode technology, gives you virtually silent operation.
With Corsair Link Digital support, you can monitor power supply performance, toggle single rail or multi rail mode, and control fan speed directly from your desktop. And, the fully modular, low profile cable set makes builds and upgrades easy, with clean, great-looking results.
  • Corsair Link. Integration for monitoring performance and adjustment of fan speed and multi-rail/single rail mode.
  • 80 PLUSR Platinum efficiency, delivering 92% energy efficiency at real world load conditions.
  • ZeroRPM mode for fanless operation at low loads and outstanding noise reduction.
  • 140mm thermally controlled fluid dynamic bearing fan spins up as needed.
  • Fully Modular low profile cables for easy installation, less clutter, and helps maximize airflow through your computer¡¦s chassis.
  • Engineered to meet maximum power output at a server-grade 50C temperature rating.
  • Fan self-test switch to determine fan functionality even before installation.
  • The latest ATX12V v2.4 and EPS 2.92 standards and is backward compatible with ATX12V 2.2, 2.31 and ATX12V 2.01 systems.
  • 4th generation IntelR Core. processor Ready (Intel Haswell and Z87 motherboards).
  • Over-voltage protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components.
Product Description CORSAIR HXi Series HX850i - power supply - 850 Watt
Device Type Power supply - internal
Specification Compliance ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification 80 PLUS Platinum
Weight 3.374 kg
Localisation United Kingdom
Input Voltage AC 100-240 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 850 Watt
Output connectors 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 12 x 4 PIN internal power , 12 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
Cooling System 140 mm fan
Dimensions (WxDxH) 15 cm x 18 cm x 8.6 cm
Manufacturer Warranty 10 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair 850W HX850i Hi...
£168.49
