Corsair 8GB (2x4GB) DDR3 1600Mhz CL9 XMS3 Performance Deskto...
Corsair 8GB (2x4GB) DDR3 1600Mhz CL9 XMS3  Performance Desktop Memory Kit
Product codes
The XMS3 family is Corsair's mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability.
Key Features
  • Maximize your system memory capacity for ultimate performance
  • Guaranteed to work on all dual channel Intel and AMD platforms
  • XMS heat spreader
  • World famous Corsair reliability and performance
Package Contents
  • Two 4GB memory modules
  • Designed for use with all DDR3 motherboards with two memory channels
  • Warranty: Lifetime
  • Size: 8GB Kit (2 x 4GB)
  • Performance Profile: XMP
  • Fan Included: No
  • Heat Spreader: XMS
  • Memory Configuration: Dual Channel Memory
  • Type: DDR3
  • Package - Memory Pin: 240
  • Package - Memory Format: DIMM
  • Tested Voltage: 1.65
  • SPD Voltage: 1.5
  • Speed Rating: PC3-12800 (1600MHz)
  • SPD Speed 1333MHz
  • Tested Speed 1600Mhz
  • Tested Latency 9-9-9-24
  • SPD Latency9-9-9-24
CORSAIR XMS3 - DDR3 - 8 GB: 2 x 4 GB - DIMM 240-pin - unbuffered
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL9 (9-9-9-24)
Heat sink, dual channel, unbuffered
Voltage
1.65 V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair 8GB (2x4GB) DD...
