Corsair Air Series 120mm Quiet Edition High Airflow Fan - AF1...
Corsair Air Series 120mm Quiet Edition High Airflow Fan - AF120 Whit
£12.22
Delivery:
Standard: 1-3 working days
Key features
  • Superior cooling performance and LED illumination
  • Tuned for high-airflow, large volume cooling
  • Better performance than standard case fans
Product codes
Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
Product Description CORSAIR Air Series LED AF120 Quiet Edition case fan
Product Type Case fan
Package Content Mounting screws for case fans
Colour White
Fan Diameter 120 mm
Fan Height 25 mm
Fan Bearing Sleeve bearing
Rotation Speed 1500 rpm
Air Flow 52.19 cfm
Noise Level 25.2 dBA
Power Connector 3-pin plug
Rated Voltage 12 V
Features White LED x4, custom-molded fan blades
Weight 140 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Air Series 120...
£12.22
