Corsair Air Series AF120 Performance Edition (Double Pack)
Key features
  • Nine ultra-thin blades for excellent airflow at very low noise levels
  • Custom fan enclosure for ducting air in the right direction with minimal interference
  • Advanced hydraulic bearing for reliable, quiet operation
  • Rubberized corners for sound damping when installed with standard screws
  • User-replaceable colored rings so you can match your fans to your case
  • Included voltage step-down adapter for even quieter operation
Product codes
The Air Series AF120 fans let you have it all. Nine ultra-thin, custom-molded blades push ample air volume. Rubber corners dramatically reduce vibration. The advanced hydraulic bearing system is quiet and reliable, and you can customize the look with the three included colored rings.
AF models performs best in unrestricted spaces with at least 3cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components Filling the case with heat. They work equally well for unrestricted intake fans, for areas like side panels or bottom intakes.
Product Description CORSAIR Air Series AF120 Performance Edition case fan
Product Type Case fan
Packaged Quantity 2 (specifications are for single item)
Package Content Mounting screws for case fans, 3 replaceable colour rings, voltage reduction adapter
Fan Diameter 120 mm
Fan Height 25 mm
Fan Bearing Hydraulic bearing
Rotation Speed 1650 rpm
Air Flow 63.5 cfm
Noise Level 30 dBA
Rated Voltage 12 V
Features Rubberised corners
Weight 200 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Air Series AF1...
