Corsair Air Series AF120 Quiet Edition (Single Pack)
Key features
  • Great choice for a quiet side panel intake or case exhaust, or even a "pull" fan for a radiator or heatsink
  • Nine ultra-thin blades for excellent airflow at very low noise levels
  • Custom fan enclosure for ducting air in the right direction with minimal interference
  • Advanced hydraulic bearing for reliable, quiet operation
  • Rubberized corners for sound damping when installed with standard screws
  • User-replaceable colored rings so you can match your fans to your case
  • Included voltage step-down adapter for even quieter operation
Product codes
The Air Series AF120 fans let you have it all. Nine ultra-thin, custom-molded blades push ample air volume. Rubber corners dramatically reduce vibration. The advanced hydraulic bearing system is quiet and reliable, and you can customize the look with the three included colored rings.
AF models performs best in unrestricted spaces with at least 3cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components filling the case with heat. They work equally well for unrestricted intake fans, for areas like side panels or bottom intakes.
CORSAIR Air Series AF120 Quiet Edition - case fan
Case fan
Package Content
Mounting screws for case fans, 3 replaceable colour rings, voltage reduction adapter
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1100 rpm
Air Flow
39.9 cfm
Noise Level
21 dBA
Rated Voltage
12 V
Rubberised corners
200 g
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Air Series AF1...
