Corsair Air Series AF140 Quiet Edition (Single Pack)
Product codes
The Air Series AF140 fan lets you have it all. Eleven ultra-thin, custom-molded blades push ample air volume. Rubber corners dramatically reduce vibration. The advanced hydraulic bearing system is quiet and reliable, and you can customize the look.
AF model is ideal for mounting at the rear or top of your PC case as exhaust fan for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. It works equally well as unrestricted intake fans for areas like side panels or bottom intakes.
Product Description CORSAIR Air Series AF140 Quiet Edition case fan
Product Type Case fan
Package Content Mounting screws for case fans, 3 replaceable colour rings, voltage reduction adapter
Fan Diameter 140 mm
Fan Height 25 mm
Fan Bearing Hydraulic bearing
Rotation Speed 1150 rpm
Air Flow 67.8 cfm
Noise Level 24 dBA
Rated Voltage 12 V
Features Rubberised corners
Weight 240 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Air Series AF1...
