Corsair Air Series Sp120 Single Pack Blue Led High Static Pre...
Corsair Air Series Sp120 Single Pack Blue Led High Static Pressure F
Key features
  • High static pressure cooling with led illumination
  • Designed for restricted spaces
Product codes
Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
CORSAIR Air Series LED SP120 High Static Pressure case fan
Case fan
Package Content
Mounting screws for case fans
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
1650 rpm
Air Flow
57.24 cfm
Noise Level
26.4 dBA
Power Connector
3-pin plug
Blue LEDs
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Air Series Sp1...
