Corsair Air Series Sp120 Twin Pack Red Led High Static Pressu...
Corsair Air Series Sp120 Twin Pack Red Led High Static Pressure Fan
Key features
  • High static pressure cooling with led illumination
  • Designed for restricted spaces
Product codes
Corsair Air Series LED high static pressure PC case fans combine efficient high pressure airflow with striking LED lighting. They're custom designed to deliver air directly to high-temperature components with less noise and turbulence than ordinary fans. The custom-molded blades are translucent and have a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series SP fan models are designed for use in restricted spaces. They're ideal for radiator and heatsink use, as well as drive bay intakes and other locations where you're mounting a fan directly adjacent to a heat source. For general purpose case ventilation where you'd like high airflow with minimal excess noise, check out our AF120 and AF140 LED fans.
  • Tuned for high pressure air delivery directly to components
  • Better performance than standard case fans
  • LED-lit translucent, frosted fan blades for a dramatic effect
  • Specially designed fan blades and a sleeved bearing system for less vibration, noise and turbulence
CORSAIR Air Series LED SP120 High Static Pressure - case fan
Case fan
Packaged Quantity
2 (specifications are for single item)
Package Content
Mounting screws for case fans
Red
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1650 rpm
Air Flow
57.24 cfm
Noise Level
26.4 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Red LED x4, custom-molded fan blades
140 g
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Air Series Sp1...
