Corsair Builder Series CX500 500W ATX PSU
Key features
  • Ultra-quiet 120mm fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
  • Up to 80% energy efficiency means less heat generation and lower energy bills
  • 0.99 active power factor corrections provide clean and reliable power
  • No more hassle of flipping that tiny red switch to select the voltage input!
  • Dedicated single +12V rail offers maximum compatibility with the latest components
  • Over-voltage and over-power protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components
  • Extra long fully-sleeved cables support full tower chassis
Product codes
Ideal for Home and Office Use
The Corsair Builder Series of PSUs are designed for worry-free compatibility for your home desktop PC system build or upgrade. With features usually reserved for premium power supplies, it's a great choice for systems where continuous and reliable power delivery and low noise are essential.
Inside you will find a power supply that conforms to universal ATX standards, a power cable, and a clear, detailed Quick Start Guide. Corsair Builder Series power supplies get your system up and running quickly and easily, for years of trouble-free operation.
Product Description CORSAIR Builder Series CX500 - power supply - 500 Watt
Device Type Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance ATX12V 2.3
80 PLUS Certification 80 PLUS
Weight 2.1 kg
Localisation United States
Input Voltage AC 90-264 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 500 Watt
Output connectors 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 6 pin PCI Express power , 5 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System 120 mm fan
Dimensions (WxDxH) 15 cm x 14 cm x 8.6 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Corsair Builder Series...
