Corsair Carbide 270R Mid-Tower ATX Solid Side-Panel Case
Key features
  • Clean and minimalist exterior design
  • Built-in cable routing
  • Direct airflow path
Product codes
Carbide series 270R is compact and engineered for building high-performance yet minimalist systems.
Corsair Carbide Series 270R - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Front dust filter, rugged, Direct Airflow Path design, supports 120 mm radiator in rear, PSU dust filters, supports 120/240 mm radiator in top, supports 120/240/280/360 mm radiator in front panel
No power supply
Specification Compliance
ATX
21 cm x 50.9 cm x 46 cm
7.12 kg
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Carbide 270R M...
