Corsair Carbide 270R Mid-Tower ATX Windowed Case
Key features
  • Clean and minimalist exterior design
  • Built-in cable routing
  • Direct airflow path
Product codes
Carbide series 270R is compact and engineered for building high-performance yet minimalist systems.
Product Description CORSAIR Carbide Series 270R Windowed - mid tower - ATX
Product Type System cabinet
Form Factor Mid tower
I/O Connectors 2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards ATX, microATX, Mini-ITX
System Cabinet Features Windowed side panel, front dust filter, rugged, Direct Airflow Path design, supports 120 mm radiator in rear, PSU dust filters, supports 120/240 mm radiator in top, supports 120/240/280/360 mm radiator in front panel
Power Device No power supply
Specification Compliance ATX
Dimensions (WxDxH) 21 cm x 50.9 cm x 46 cm
Weight 7.28 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Carbide 270R M...
