Corsair Carbide Clear 400C Carbide Series Compact Mid-Tower Case
£82.92
Delivery:
Standard: 1-3 working days
Key features
  • Easy to build
  • Hinged and latched full side panel window
  • Clean, modern lines
  • All-steel exterior
  • Direct Airflow technology
  • Compact design
  • Two included fans
  • PSU and bay covers
  • Easy to clean
Product codes
The Carbide Clear 400C packs all the performance and expandability you need into a beautifully compact case design. Put your components on display through the gorgeous, full-size window panel that opens with a touch - and keep it all running cool and quiet with Direct Airflow technology.
  • Clean, modern lines with an all steel exterior.
  • Full side panel window to see your internal parts, complete with tool-free latch and hinge for easy access.
  • Compact Mid Tower design fits full sized ATX boards and multiple graphics cards.
  • Direct air flow access to the hottest components with no drive cages in the way.
  • Capable liquid cooling support for both CPU and GPU loops.
  • Included AF140L and AF120L fans for excellent performance and low noise levels.
  • PSU and 3.5h modular covers conceal cables and drives, and can be relocated or removed entirely for easy assembly.
  • Full dust filtration on bottom, front, and top.
  • Tons of cable-routing options and tie downs so cables can be easily tucked out of the way.
  • Tool-free drive installation for quick builds.
  • Front radiator compatibility for up to a single 360mm radiator or multiple 120/140mm radiators.
CORSAIR Carbide Series Clear 400C - mid tower - ATX
System cabinet
Mid tower
White
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Windowed side panel, top panel dust filter, front dust filter, Direct Airflow Path design, bottom dust filter
No power supply
Specification Compliance
ATX
21.5 cm x 42.5 cm x 46.4 cm
8.2 kg
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Carbide Clear...
£82.92
