Corsair Carbide Series™ SPEC-01 RED LED Mid Tower Gaming Case
GREAT LOOKS, SMART DESIGN & DURABLE CONSTRUCTION @ A GREAT PRICE!
Key features
  • Huge side panel window
  • LED front intake fan, with room for more
  • Flexible cooling potential
  • Multiple drive bays
  • Easy system builds, maintenance and upgrades
Product codes
Carbide Series SPEC-01 is proof that great looks, smart design, and durable construction don't need to be pricy, and that basic doesn't need to be boring. You get aggressive styling, a huge side panel window for admiring your components, and an LED-lit front intake fan that draws cool air directly to your graphics cards.
Inside, there's room for up to five fans, and the four combination hard drive / SSD trays make storage installation and upgrades quick and easy. Cable routing cutouts help you reduce clutter, and the built-in dust filters help protect your components. Up front, the USB 3.0 connector gets you up to speed with the latest high-performance storage devices.
  • Tons of fan mounts: Front - 2 x 140/120mm (1 x 120mm LED included), Top - 2 x 120mm, Rear - 120mm
  • USB 3.0 front port with internal connector
  • Large side panel window
  • Cable routing and CPU cooler backplate motherboard cutouts
  • Seven PCIe slots with room for long graphics cards up to 420mm long
  • Install up to four storage drives, your choice of 3.5" or 2.5", each tray fits both.
  • Dust filters for front and PSU intake.
Box Contents
  • Carbide Series SPEC-01 Mid Tower Gaming Case
  • Accessories box with screws, zip ties, and other mounting hardware.
  • Warranty and Support Information
CORSAIR Carbide Series SPEC-01 - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
1 x USB 3.0 , 1 x headphones , 1 x microphone , 1 x USB 2.0
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Windowed side panel, screwless drive bays, front dust filter, CPU cut-out, cable management holes, supports 120 mm radiator in rear, PSU dust filters
No power supply
Specification Compliance
ATX
20 cm x 44.7 cm x 42.8 cm
4.8 kg
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Carbide Series...
