Corsair Carbide Series 275R ATX Case - White
£64.76
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Minimalist design, maximum features
  • Full window side panel
  • Clean and minimalist design
  • Expansive storage space
  • Built-in cable routing
  • Direct Airflow Path cooling
  • Case Form Factor: Mid tower
  • Motherboard Form Factor: ATX
  • Colour: White, White
  • Stock Status: In Stock
Product codes
The CORSAIR Carbide Series 275R is a compact mid-tower ATX case that matches minimalist design and a beautiful tempered glass window with a straightforward interior layout and versatile cooling options.
Product Description CORSAIR Carbide Series 275R - mid tower - ATX
Product Type System cabinet
Form Factor Mid tower
Colour White
Built-in Devices RGB lighting
I/O Connectors 2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards ATX, microATX, Mini-ITX
System Cabinet Features Front dust filter, cable management holes, meshed top, acrylic side panel, Direct Airflow Path design, supports 240 mm radiator in top, PSU dust filters, Liquid Cooling Ready, supports 280/360 mm radiator in front panel
Power Device No power supply
Specification Compliance ATX
Dimensions (WxDxH) 21.1 cm x 45.5 cm x 46 cm
Weight 10.14 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Carbide Series...
£64.76
