Corsair Carbide Series 275R Tempered Glass ATX Case - Black
£73.00
Delivery:
Key features
  • Minimalist design, maximum features
  • Full window side panel
  • Clean and minimalist design
  • Expansive storage space
  • Built-in cable routing
  • Direct Airflow Path cooling
  • Case Form Factor: Mid tower
  • Motherboard Form Factor: ATX
  • Colour: Black
Product codes
The CORSAIR Carbide Series 275R is a compact mid-tower ATX case that matches minimalist design and a beautiful tempered glass window with a straightforward interior layout and versatile cooling options.
Product Description CORSAIR Carbide Series 275R - mid tower - ATX
Product Type System cabinet
Form Factor Mid tower
Colour Black
I/O Connectors 2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards ATX, microATX, Mini-ITX
System Cabinet Features Windowed side panel, front dust filter, cable management holes, meshed top, supports 240 mm radiator in top, tempered glass side panel, PSU dust filters, supports 280/360 mm radiator in front panel
Power Device No power supply
Specification Compliance ATX
Dimensions (WxDxH) 21.1 cm x 45.5 cm x 46 cm
Weight 10.14 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Carbide Series...
£73.00
