The CORSAIR Carbide Series 275R is a compact mid-tower ATX case that matches minimalist design and a beautiful tempered glass window with a straightforward interior layout and versatile cooling options.
Product Description | CORSAIR Carbide Series 275R - mid tower - ATX | Product Type | System cabinet | Form Factor | Mid tower | Colour | Black | I/O Connectors | 2 x USB 3.0 , 1 x headphones , 1 x microphone | Supported Motherboards | ATX, microATX, Mini-ITX | System Cabinet Features | Windowed side panel, front dust filter, cable management holes, meshed top, supports 240 mm radiator in top, tempered glass side panel, PSU dust filters, supports 280/360 mm radiator in front panel | Power Device | No power supply | Specification Compliance | ATX | Dimensions (WxDxH) | 21.1 cm x 45.5 cm x 46 cm | Weight | 10.14 kg | Manufacturer Warranty | 2-year warranty |
General | |
Max Mainboard Size | ATX |
Internal Bays Qty | 5 |
Product Material | Steel, tempered glass |
Colour | Black |
Cooling System | Front: 120 mm fan x 1 / 3 x 120 mm or 2 x 140 mm fan supported , Rear: 120 mm fan x 1 , Top: 120 mm fan mount x 2 |
CPU Cooler Max Height | 170 mm |
Video Card Max Length | 370 mm |
Power Supply Max Length | 180 mm |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 2 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5" |
Expansion Slots | 7 |
Interfaces | 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack |
Miscellaneous | |
Included Accessories | Accessory kit |
Power | |
Dimensions & Weight | |
Width | 21.1 cm |
Depth | 45.5 cm |
Height | 46 cm |
Weight | 10.14 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
