Corsair Carbide Series 88R Mid-Tower USB3.0 microATX Case Black
£44.17
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Elegant, modern design
  • Front support for 240 mm radiators
  • USB 3.0 front panel port
  • Tool-free 3.5" and 5.25" drive installation with easy SSD support
  • Direct airflow to the top GPU
  • Up to five fan mounts, and one included 120 mm fan
  • Thumbscrew side panels
  • Flush-mounted side panel window
  • Cable routing channels and holes
  • Modern internal layout
  • Case Form Factor: Mid tower
  • Motherboard Form Factor: Micro ATX
  • Colour: Black
  • Stock Status: In Stock
Product codes
Carbide SeriesĀ® 88R MicroATX Mid-Tower Case
Compact, Elegant, and Easy to Build
The Carbide Series 88R microATX mid tower has all the modern features you need, with SSD compatibility, USB 3.0, and room for full sized graphics cards and power supplies. Room for five 120mm fans offers you excellent cooling potential and the clean, modern design and large window make the case as beautiful as it is functional.
The 88R also fits up to a 240mm front panel radiator if you're upgrading to liquid cooling, and the various tool free drive and cable routing options means your build will be fast and easy.
The 88R is both professional enough for the office, and customizable enough for any home PC build.
Front support for 240mm radiators
The front-mounted 240mm dual radiator mount makes it easier to upgrade your CPU or GPU to liquid cooling.
It's easy to connect modern high-speed peripherals.
Installing or upgrading your storage no longer has to start with finding your screwdriver. And since the 88R has built-in mounts for high-performance 2.5" SSD drives, no separate adapter is necessary.
The smart design channels air directly to your graphics card to provide it with the cooling it needs for intense gaming.
Up To five fan mounts, and one included 120mm fan
A 120mm fan gets your cooling off the ground, and extra mounts provide added expandability.
Access your system's components with the twist of your fingers.
If you take pride in your work, you can show it off.
Builds are further simplified and aesthetics improved with easy cable organization.
The modernized interior makes building your dream PC easier while improving overall performance.
Package contents:
Carbide Series 88R MicroATX Mid-Tower Case
Accessory kit
Warranty and Support Information
Compatibility
MicroATX and Mini-ATX motherboards.
Technical specifications
Front support for 240mm radiators: Upgrade your CPU or GPU to liquid cooling with support for a 240mm front radiator.
USB 3.0 Compatible: USB 3.0 front panel port for modern high-speed peripherals.
SSD Support: Built-in mounts for high-performance 2.5" SSD drives.
Direct Airflow to Top GPU: Direct airflow gives your GPU added cooling for intense gaming sessions.
Up To Five Fan Mounts and One Included 120mm Fan: A 120mm fan gets your cooling off the ground, and extra mounts provide added expandability.
Tool-free 3.5" and 5.25" Drive Installation: Builds are made easier with tool-free drive installation.
Thumbscrew Side Panels: No tools are needed to easily access the inside of your case.
Flush-Mounted Side Panel Window: The side panel window showcases your PC's components.
Cable Routing Channels and Holes: Builds are further simplified and aesthetics improved with easy cable organization.
Modern Internal Layout: The interior makes building your dream PC easier and improves overall performance.
Product Description CORSAIR Carbide Series 88R - mid tower - micro ATX
Product Type System cabinet
Form Factor Mid tower
I/O Connectors 1 x USB 3.0 , 1 x headphones , 1 x microphone , 1 x USB 2.0
Supported Motherboards microATX, Mini-ITX
System Cabinet Features Windowed side panel, screwless drive bays, cable management holes
Power Device No power supply
Specification Compliance ATX
Dimensions (WxDxH) 19.8 cm x 44.8 cm x 37.8 cm
Weight 4.8 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Carbide Series...
£44.17
